Replacing shift cable. What are these parts for?
lr3guyjoe
I just got a GLM21450 shift cable kit and I’m a little unsure what these parts are for. The plastic watcher the little metal wire and the orange plastic piece.
EBRAMS
The orange Thing is a tool that holds the end of the shift cable when reinstalling the drive its great use it.
The metal wire is safety wire that holds the set screw on the shift slide in place.
The plastic washer goes on the shift shaft Picture attached
lr3guyjoe
Thanks a bunch! I have seloc manual and your diagram was more helpful ha.
airshot
Damn after all those years of wrestling that arm into position, now I find there are tools for that !!!
Grub54891
Do not tighten the set screw to tight! Just snug it up and back it off a real tiny bit. If too loose, shifting will be impossible to adjust, to tight and the cable will bind.
