Replacing Shift Shaft alignment
KCIDirect
After replacing the LU in my Mariner 75hp 1985 outboard, and turning over the motor I see the prop is turning. I assume this is not correct, it should be in neutral and not turning. I have not started the motor and concerned that I have improperly inserted the "shift shaft" cable. The prop clicks when I turn clockwise and locked when turned counterclockwise in forward, neutral, reverse. Don't see any other posting, is there a way I can be sure this cable is properly aligned and inserted? What is the proper procedure for replacing the LU for proper connection/insertion of exhaust, drive shaft, water pump tube, shift shaft and pins? Thank You :rolleyes:
