replacing the bellows
beanz2166
Im planning on replacing my bellows in the next few weeks, Im wondering is it nessecary to buy all the "special" tools recommended? I know some like the hinge pin, are needed but do I really need to buy the bellows expander and some of the other stuff?
achris
More fish than mountain goat
Re: replacing the bellows
What are you working on? If it's a Gen II, I recommend you use the installer tool for the uni bellows. Yes it can be done without it, but it is SO much easier with it (and a can of Power Tune)... and the hinge pin tool. You only need the bellows expander tool for the exhaust bellows.
Chris....
boozer1966
I changed bellows on a Mercruiser 140 with an Alpha One MR outdrive last year. No prior experience, and I found the exhaust bellows tool to be invaluable. Highly recommend it. Definitely worth the money.
slag
I've done it without on an alpha 1. Wasn't worth the $45.00 or so they want for the tool. Maybe if I did 10 of these a year but not worth it at least for me.
Ayuh,.... Whatcha workin' on,..??
a 1/2" allen key works insteada the hinge tool,...
A Gen.II drive bellows requires a can of Power Tune, 'n yer fingers,...
The exhaust bellows expander is Required to get the darn thing On, No way 'round it...
But if yer kinda "Handy", makin' 1 is pretty easy...
A 1/4" drive socket set, with several different length extensions, 'n wobblies is Invaluable in that Job too....
Regardless which drive yer workin' on....
Hoosmatroos
In the Netherlands we have an expression for these things:
"Goed gereedschap is het halve werk"
When I translate it, it would be something like:
"Good tools do half the job"
Nothing is more true in my opinion.
