Re: Replacing The Floor On My 14 foot Starcraft
Made lots of progress once I got the floor materials right. Attached pictures show all four floor panels set in and fit up. Nothing tied down yet but the fit is pretty good. I will need some longer grip range rivets to attach the floor to the ribs. The wood is 15/32 and the rib has some thickness to it plus there can be a small gap between the wood and where the rivet hits the rib. I'm thinking a grip range of .5" - .625" should do it. I also need to fabricate a joiner plate where I have a joint in the floor that wasn't in the old one. I'll just buy some aluminum strapping and rivet it along the edges like the original joints have. It falls under the live well and the console so there'll be lots of screws that span the two sheets too. The only place you'll even see it is in the narrow passageway in between them.
My next thing to focus on is the live well plumbing. It looks like they used through hull fittings to join the pipe to the bottom of the well. I've looked on-line and I'm not sure I can buy the same types but I think I can make the modern ones work. In the old ones the cap on the inside of the live well threaded on and there was a locking nut on the outside. It would be easy to pull the pipe up with a nut on the inside but the fittings I've located all have the inside flange as a integral part of the threaded fitting with only the one nut. That means I'll have to install the live well with the pipe attached and fish the pipe under the floor to the stern. If I leave the stern section of the floor out until that's done, it shouldn't be too hard (I hope).
I'll going to redo the three rivets I put in and seal them with LocTite epoxy. I also still need to clean the interior of the hull and seal the floor boards. My garage isn't heated so I'll need to wait a little while for warmer weather for the sealing.
It feels great to be putting things together instead of taking things apart for a change.
Thanks for all your help.
1988 Starcraft.
