Replacing the stringers, found a problem.
NEStriper
Re: Replacing the stringers, found a problem.
Well, I got it on supports combining your diagram woodonglass and a few ideas I've seen on the board. I'll post pics later. I removed that rotten piece of plywood that was glassed to the deck, however, I only removed one half and the center piece. I did this so that the other side would still have some support for me to walk around on while I glassed in the other side. Once the wood I removed is replaced, I'll take out the other side and glass that in. Once it's all replaced, I'll do the stringers.
Of course, I discovered that the transom was shot today too. Denial is not just a river in Egypt. What is the order of events? Remove transom before replacing the stringers?
Woodonglass
Yep, take out the transom first. Stirngers should tie into the transom for extra strength.
