I removed my original VRO Fuel Pump today and replaced it with a non VRO Johnson/ Evenrude/ OMC replacement unit. The engine is a 1996 vintage OMC Turbojet 115.
The new fuel pump by-passes the pulse limiter hose and bolts right to the block. I pluged the Pulse Limiter intake when I hooked up the fuel pumpt directly to the block. The fuel intake and supply lines are obvious. My curious question is, what does the other 1/4" line that runs from the VRO to the block do? Do I plug it? Do I leave it as a vent? Or do I tee it into the other 1/4" lines that run to the bearings???? Also, this is not the oil line that goes to the oil tank (thats was long ago disconnected and plugged), it ran from the VRO to the block and attached to a nipple via a nylon hose clamp.
Thanks for any thoughts.
Troy
Troy
