Reply to the post for 6 &7 of June
buda
[ Sorry about beening late to reply. ordered impeller and they sent me the wrong one. Ordered another one and it was the right one. Put it in and took boat to river and it pumped water just fine. Even works with the muffs now. I have a new problem now. after running it down the river about 5 miles it ran great at WOT and even mid throdel. Got back to the dock and the buzzer was sounding. Don't know why because it was pumping water. I shut it off and it would'nt start .For some reason i decided to pull the flywheel and take a look. The stator was black from getting hot. {2} the bottom of the trigger assy was all chewed up and so was the bottom of the bearing cage and the bottom of the flywheel. Looks like the bottom of the flywheel was causing the problem. Is the bottom of the flywheel suppose to touch the crankshaft bearing cage.
Thanks Buda
jerryjerry05
Re: Reply to the post for 6 &7 of June
No.shouldn't touch anything.Post some pics.J
buda
jerryjerry05 How do i at the pictures.
Thanks buda
TwoFish
To upload files the files needs to be a jpg format and around 180kb.
The process is as follows
Select ?Reply?
Select ?Go Advanced? a new window will appear.
Type your message in the normal text box.
Look further down the page to find the attachment box.
Select ?Manage attachments? a new window will appear.
Select ?ADD Files? a new window will appear.
Select ?Select Files? a new window will appear. This window shows the files on your computer. Go to where you have stored them and select the ones you want.
Select ?Upload Files?. This will upload the files to Iboats.
Select ? Submit Reply? and your photos will be sent with your message.
Hope this helps.
buda
[ Im trying to post some pictures, so here go's These pic are of the stator.trigger ,crankshaft bearing cage and the flywheel that was damaged when i took the boat out to check the impeller. I think this motor is jinks.
buda
Thanks TwoFish , pictures are uploaded now
Buda
BuzzStPoint
I'm no expert. Unless you have the wrong flywheel entirely.. (Which I would think the engine wouldn't run)
I would venture a guess the lower plate screws rattled loose. Once it rubbed off the heads of the screws it was all over from there.
jerryjerry05
Looks like Buzz is right.Post a few pics of the top of the crank where all this stuff goes.
You might get away with some new parts.J
buda
I had an extra flywheel, trigger, crankshaft bearing cage and stator from parts i had before. I put those on an put some tool and dye ink on the bearing cage and put the flywheel on and turn the motor by hand to see if it was touching. Sure enouth it was rubbing. So i took everything back off and took the bearing cage and milled it down about 1/8 inch. put it bact together and checked it NO RUBBING. Tomorrow i'm going to start it up with muffs and see what happens. Thanks guys i appreciate all the help.
Buda
buda
Tried to start it today, would'nt start carbs flooded but no gas on the plugs. Was rubbing on the bearing cage but no to bad. This motor has been nothing but a jinx since i bougth it fix one thing an another goes out. Im constandley working on this motor. I think its about time to replace it. Ive got more time and money in this thing than its worth. I want to thank everybody for thier input. Its people like you that makes this a great help site.
Thanks Buda
