Repowering costs?
Bayliner2252
If I were to repower from a 4.3L merc w/ alpha 1 to a 5.0 or 5.7 what am I looking at for approximate costs? Thanks!
HT32BSX115
Re: Repowering costs?
Howdy,
It depends of course, on how you obtain your engine & drive and whether you do it yourself or pay someone else. The difference can be several thousand $$
If you go from a 4.3 engine to a 5.7, you *should* also either replace the drive or change the gearing. depending on how you do that will determine the costs.
If you get a junkyard (truck) 5.7L engine, and use the 4.3L drive, and change the prop to a MUCH higher pitch to compensate.......It'll "work" and you do it all yourself, will cost you the engine, prop, and engine mount fab work and any other parts you need like manifolds, risers, etc. (I think the flywheel housing/coupler might be the same depending on the year model of your 4.3 and teh 5.7 you use)........someone will jump in here on this.
The best way to do it would be to find a rotten boat with the engine/drive you want and swap it ALL over.
Regards,
Rick
Bayliner2252
Thanks HT32,
I'm handy with maintenance on cars and boats but an engine swap is beyond my capabilities. I'd have to have someone do it. Boat is a '94 for and engine/drive is original.
HT32BSX115
Thanks HT32,
Just looked at a youtube video of a Bayliner 2252/4.3L
If you could do all the work yourself and scrounge all the parts and a junkyard engine, it *might* be worth it.
If you have to pay someone to do do it (and it should be a marine dealer, not a backyard mech) It will cost you FAR more than the boat will be worth when it's done.
I would suggest selling it and getting another boat that is equipped the way you want...
Cheers,
Rick
