Re: Repowering from Gas to diesel
Dude, like my struggles with steam engine torque, you're missing it on this one. You're assuming that it is only possible to inject or draw some limited amount of fuel in just because the density is lower. Why can't I put twice as much propane in and get more power? Fact is you kinda can.
One absolutely can.........and I really do get it. If someone were to engineer and build an LPG or NG engine for a boat they would certainly build an engine that would take advantage of direct injection, higher compression ratio and/or supercharging. Doing that would
approach higher efficiencies and higher HP output. But it's not something a "backyard" mechanic can do which sort of describes most "home-modifiers"..........
Using the highest tech LNG system would be good too........... the fuel tanks would be smaller. (but don't try to buy an LNG tank for a
recreational boat though. Not only is there NO USCG/DOT approval for one, but none exist.....and if they did, they would probably cost DOUBLE !
I found one that holds 46 gal of LNG. Full, it's about 400lbs! The stuff on NG efficiency I found indicates that even when you design an engine ON PURPOSE to run on NG, (according to Detroit Diesel) it still takes nearly double the fuel to go the same mile (or hour) ............. So that 46 gallon LNG tank is approx equivalent to around 25 gallons of diesel fuel in it's aluminum or (very light)plastic tank
There is work being done on big ship natural gas fuel etc (you probably already know about that!)
Currently, for recreational boating/cruising, diesel or gasoline is really the only option........and diesel is the absolute safest.
NASCAR they now run E10 I think it is. They get poorer MPG due to the density drop, but they are making slightly more power due to the increased octane and associated compression increase.
With E10, you can build an engine that will get the "same" mileage as an engine running on gasoline. The difference in energy content is nearly insignificant. (E10: 111,000 btu, Gas: 115,000)
I believe they've also have tried using E85 for racing....don't know how that went...........
