Hi,
I'm repowering a Volvo 4.3L V6 with a new 2011 GM Vortec 4.3 V6. The drive is a 1988 VP 290 SP.
I have some concerns about compatibility:
The old flywheel is 12-3/4 in, the new one that comes with the engine is 14in. Do I need new bellhousing or can I reuse the flywheel and vibration dampener from my old setup? Or can I use the old housing with the new flywheel. I can't image the old starter would be compatible with the 14 flywheel.
Assuming the engine blocks are the same dimension, since they are GM V6 4.3 blocks, any issues using the old engine mounts?
In order to make sure the new engine exhaust lines up correctly with the exisiting exhaust pipes, should I be ordering the same exhaust and risers components as my old engine? Again assuming the engines have the same block dimension.
Thanks in advance,
Alex
Thanks in advance,
Alex
