Repowering with 5.7 Vortec long block which intake manifold and carb
84EdH
I am repowering my 1979 Century with a new vortec longblock and am looking for some advice on an intake manifold. I am in fresh water lakes in Pennsylvania and cool with raw water.
also, I have a Rochester quadrajet and a newer Weber (1995 Merc 350 Alpha) 4 barrel.
any suggestions on which carb to use?
thanks
Ed
Re: Repowering with 5.7 Vortec long block which intake manifold and carb
Ayuh,... The Weber on a dual-plane manifold of yer choice...
84EdH
ok, that was easy.
dan t.
Use the q-jet , far better carb, better fuel metering, triple boost venturies,will give you better idle and low speed throttle response and better fuel milage. Edelbrock manifold is as good as any.
FreeBeeTony
The Edelbrock 1409 worked great for me right out of the box.......only needed to tune the idle mixture.
dan t.
Try them both, the Edelbrock performer will accept either one , then judge for yourself. The q-jet will always get better fuel milage.
