reproduction hull ID plates?
crovowen
Are there any companies that will remake or reproduce aluminum hull ID plates? I would like to replace mine since with all the rebuilding and upgrades putting the old barely legible ID plate back on just doesn't seem right.
any suggestions?
Crow
Watermann
Re: reproduction hull ID plates?
Are you needing the capacity plate or HIN plate? Front what I've seen online there are no repop plates, only decals. I ordered a new capacity decal from the guys in the link below and put it on a backer piece of polished aluminum and then screwed it on my transom.
Boat capacity sticker replicas | GarzonStudio.com Just find the one closest to yours and add the data from your old plate.
This is how mine turned out.
southkogs
^^^^ He got what I was thinkin' of. :)
crovowen
Preferably the HIN, but i guess if the capacity labels would have the hull id and manufacturer, that would be OK also-
Crow
Watermann
I had to have a HIN assigned by the State for my 1970 Starcraft since it was not required by the CG when the boat was made. I intend on making my own HIN plate with punches on a piece of aluminum and then rivet it to the transom. I looked around online some for a custom made one but found the cost to not be worth it. The only place I found is a pain, you have to do the request a quote thing at their website.
Vin And Hull Plates | Machine Plates Online
crovowen
I knew I could count on you guys for the best info- gives me a direction to go-
Greatly appreciated!!!
Crow-
roscoe
An easy way to get HIN stamped on a plate is at a trophy shop.
Hey, thanks for the information Watermann. I just happened to be thinking about getting a new capacity plate made for a boat I'm rebuilding as the existing one is pretty tore up.
