JarFisch
Thread starter- Joined
- Jun 28, 2010
- 14
1) What *precisely* is the purpose of incorporating the 7/16" spark-gap setup prior to performing the Reeves timing procedure? -- I mean, what effect does the size of the spark-gap have on the timing parameters? ((why wouldn't we want to use the operating gap (.030) of the actual plug used during normal engine operation?))
2) On the current motor I'm dealing with (J90TLEOR) there isn't a rubber-tipped max-advance stop screw as found on earlier 70's engines and referenced by the J.Reeves guide. -- Instead, there is a thumb-wheel nut (and jam-nut) on the spark-advance rod which connects the timer base arm to the throttle lever. -- So it's somewhat unclear to me as to how to follow the Reeves' description for setting "maximum-advance" of the timer base prior to cranking and checking with a timing light. -- In other words, should I run the thumb-wheel nut all the way out to it's limit and start from there?... or perhaps do something different than that?
Thanks very much,
charlie
Thanks very much,
charlie
