msmith7113
Thread starter- Joined
- May 2, 2010
- 4
recently purchased an older pontoon with a 1989 Johnson 60hp. Probably set up about 2 years.
Done so far:
new gas tank, new gas, new fuel filter, new plugs. Carburetors were rebuilt by professional marine mechanic and supposedly tested to make sure motor was running.
After the mechanic work; I cranked it today. Ran smooth idle for a couple of minutes; then started running rough. It will continue to idle if I keep pushing in and releasing the choke. Seems like it may run better with throttle but the engine died occasionally when I put it gear.....but not every time.
Thoughts and suggestions are appreciated.
Mike
Done so far:
Mike
