Respirator needed with Enamel paint hardener???????
appleo
Obvioulsy if you are spraying......
But what about just brushing or rolling on my aluminum hull?
zool
Re: Respirator needed with Enamel paint hardener???????
I would wear it just opening the can.....its a silent killer.....but ive seen ppl spray it with just a dust mask....better safe thn sorry imo
briangcc
Depends on a number of factors...what enamel you're actually using, where you're applying it, etc. For me, I'd be wearing one.
I was spraying Krylon last fall to touch up my trailer. I was outside with a slight breeze. My dad was on the opposite side of the trailer prepping that side for touchups. The boat was on the trailer at this point, and he was getting the effects from the paint after I sprayed (1) upright on my guideposts. I couldn't smell a thing as I had a respirator on. I gave him my spare and we were able to complete the repairs with little fan fare.
**I painted for a number of years without one (including basecoat/clearcoat on cars) and once I started using one, I will not go back to not wearing one when painting.
81 Checkmate
I just got done using this a few weeks ago…….the stuff smells when you open the can.
As Zool pointed out …Better safe that sorry!
appleo
So would it just be a genearl 3m respirator for paints? Or is the hardener someting else?
zool
When it comes to ISO's, thats a debated subject. For liabilty reasons, the manufacturers state that even the organic filtered masks wont protect fully, but off the record, they kinda do.
for brush/rolling, you're not atomizing the mixture, so its not as bad. For spraying, an air fed system is the way to go, especially indoors.
Just remember, its cyanide youre dealing with.
Ive used a paint grade 3m organic filtered mask, for non spraying......if you can smell it, you're not protected is a guideline.
jigngrub
Do you plan to spray indoors or outdoors?
Indoors, I'd get the best respirator I could. Outdoors I might just go for a paint respirator.
appleo
Ouside..i have a lean to attached to my barn...open ends north and south
Bwana Don
My 2 cents:
If you're not spraying the paint won't atomize and the health risks are far less. I'm planning on rolling my boat and using Rustoleum with hardener. I'll use a mask from the time I open the can until I'm done.
If you're spraying I'd use a Hobby Air fresh air supply or similar.
Woodonglass
Honorary Supreme Mariner
I'd use this one with the best filters. Less than $100 bucks online. Works great for Grinding too!!! Rolling is not as bad as spraying by a LONG shot but why take a chance. But hey I'm an old fart so what do I know.
