eavega
Thread starter- Joined
- Apr 29, 2008
- 1,377
Hello Folks
I have a boat that I purchased about a month ago for $400. Its a 1972 15' Chaparral tri-hull for which I have not been able to find any information about. The boat has a 50 HP Evinrude motor, which I have verified runs, shifts, etc. My dilemma is that the boat needs a new transom and a new deck. The stringers seem to be in good shape even though there was wet foam underneath the floor (Deck had been replaced on the mega-cheap, unsealed plywood screwed into the stringers). I plan to re-do the transom and the floor, including replacing the foam. I've started estimating materials for this work, and have come up with a figure of about $450-$500.
There is a guy here who has been advertising a 15' Glasstron tri-hull (with no motor or seats) for $450. I contacted him to get some details about his hull, and he tells me that its rated for 115 HP outboard. He claims the transom and floor are solid, and that the boat has always been kept indoors, etc, etc.
Obviously if the boat is in good shape, I'd be on the water quicker if I purchased the Glasstron, swapped out the seats, motor, etc, and for the same money. My problem comes with the motor rating. These boats are similar in size and style (both are 15' tri-hulls), so if the Glasstron boat is rated for a 115 HP, will my 50 HP be able to push i? I have no way to compare the weight on the two, but I am sure the 50 HP pushes the Chapparal at about 30-35 MPH depending on the load in the boat.
Then comes the problem of what to do with the old hull...
I'm attracted to doing the repairs myself, because that was I am sure that the transom and deck are in good shape. Reality of it, though, is that I will probably keep this boat for only 3 or 4 years tops, then trade up to something bigger.
This boat will mostly see use as a fishing boat, but will occasionally take the family out for a day of cruising around the lake.
Any sage words of advice?
Rgds
Eric
Rgds
Eric
