Restoring a 1959 50hp v4 evinrude
Status
Not open for further replies.
PmDavis300
Re: Restoring a 1959 50hp v4 evinrude
maybe they changed the design in '59? no hoses on the manifold. ill double check next time im working on it though
PmDavis300
well i looked at the manifold diagram in my manual, i see the hose your talking about on the diagram, but i for some reason do not have that hose on my engine. they must have changed something.
dorsett59
Replacing the carb float should drastically reduce the amount of fuel that gets dumped into the crankcase and then overboard. After 50 years, the carb float (originally plastic) is fuel-soaked and does not do its job properly.
Watch out for bad seals on the lower end. I need to tear apart my lower end due to massive leaks (leading to that water sheen they're talking about) and replace those. Good luck to all of us finding parts for these monsters!
F_R
This thread is over 10 months old.
dorsett59
And somebody searching the forum for useful info on this engine might still appreciate the help. I found it when it was six months old, and it helped a great deal.
The carb float on that motor was lacquered cork, with a brass clip that held the pivot rod.
PmDavis300
thread starter here. yes this is an old thread, but helps me, maybe this spring i will replace the float. im sure its 20+ years old. im glad this post helped others
Hey all, looks like you guys have a good forum going here.
I aquired a boat last fall with a 1959 evinrude on it. so far i have rebuilt the carb and replaced all fuel lines and got it started. i have some more parts on the way for the lower unit... anyways i was wondering if anyone has any experiance with this unit? just wondering what your opinion on it is and if you have any tips for me.
Thanks!
-Peter
Hey Peter, i am interested in finding a 1959 50hp evinrude motor. That was the first motor i had on my first boat, and i am interested in finding one for myself i am just now activly trying to find one and a wooden mahogany boat to go along with it. Please contact me at 978-335-9977 or
cj21796@hotmail.com
Thanks!
-Peter
these motors are known for eating up the clutch dogs in the lower unit but you should no this a powerful motor that in my opinion would put any new 50 hp to shame i wish i was so lucky to have one of my own!!!!
W_Guy
I just found it TODAY and I find it very useful since I just bought a '58 "fat fifty"!
The knowledge here is very much appreciated.:D
Spyderdan
I know this is an old thread but for those who come across this information I wanted to add that on my 1960 75HP starflite II motor there is a crank case drain (raw fuel/oil) line that is located at the bottom left of the block that runs around the left side of the engine (if your facing carburetor) to the exhaust where the raw fuel is dumped. You can intercept that wasted fuel mix and send it to a catch can or back to the fuel tank to improve fuel economy.
In this EPA report from the early 70s several outboards were tested and the old V4 motors waste about 30% of there fuel at idle by draining it straight out of the exhaust! https://nepis.epa.gov/Exe/ZyPDF.cgi/9101RUE1.PDF?Dockey=9101RUE1.PDF
Status
