Coming from you that's a pretty big compliment. Thanks.You do very nice work, and you appear to be moving very quickly. I feel you about blowing through materials. I've burned through 9 gallons of resin in the last 3-4 weeks.
I was being lazy and stupid when I did the first batch of grinding and didn't tent the boat or protect the garage. Ugh, deep cleaning is an understatement. After that first time, I now tent the boat and hook up 2-6hp shop vacuums to a plate I made to go over the keyhole.Yeah, grinding was definitely my least favorite so far. Once I finish the boat I'm going to have to do a serious deep clean of the garage from the rafters down to get all the leftover dust out. I'm also looking forward to the mechanical side of things. What's it take to go from an Alpha One Gen 1 to a Gen 2? Why the change?
Everyone makes those hockey pucks sooner or later.Stringers in !
Whew, a lot of work. I made some quick aluminum spacers on our CNC plasma table today just because I do better with metal than wood (lol).
I underestimated the time to bed in 2, 8' stringers and mixed the first batch of PB too hot and ended up losing over half the mix...grrrrr.
Tomorrow, finish the fillets and start the tabbing. Looks to be a long day, gotta remember Valentine's dinner or else.![]()
Oh Boy, we would have to start a new thread on probably a different forum to go through all the cars I've built, LOL.You build race chassis? Tube welding is something I always wanted to get into. I've got the welder, just need a bender and a notcher. Do you still do anything with race cars? I do import 1/4 mile drag racing as a hobby.
Looks good , this build is very similar to what I just did with a 1993 Larson SEI 180 , transom slightly different but was made the same with 1/2'' sheet stapled over 1'' larger area of the transom, i replace it with 2 x 3/4" for the whole area. As for what you call the shelves , since they are only holding in place with some chopped strand on top and one layer on spray foam with a bit more chop gun, i was inclined to think not structural. The only explanation I had was in my boat they were only there to provide a level bottom surface for the storage on the side. I had enough room underneath to tab in new floor but from the shelf to stern I had to cut and remove this layer of chop gun and spray foam to get proper tabbing to hull. If you check my last post Larson SEI 180 Complete Rebuild | Boating Forum - iboats Boating Forums you can see how I covered it, not sure if it good or not but could not think of other solutions. As for the gas tank cover, to avoid screwing in the stringers, which are all covered with 6oz cloth and epoxy, I epoxied pieces of 1/2'' ply to stringers that I can screw into, if rot gets in them it will be isolated from structural members as long as they can hold those screws life is good. Boxing in that shelf may not be a great idea, it may change dynamics on how the hull flexes laterally, causing higher stress in an area not designed for it. Again just an opinion probably be fine but I would hate seeing the gel coat spidercrack at that exact location along the hull. Sorry I don't have many pictures posted can look for more if you need em.OK, I'm looking for a little advice from the group. I hope I can explain this right. My boat has two "shelfs", or compartment bottoms that are glassed into the sides of the hull around 6-8' long. The purpose (or at least main purpose) of these is that they make up the bottom of the integrated storage pockets that run along the gunnels from the helm to the rear seats @ the transom. These are approximately 1" thick and 4" wide. They are glassed to the hull and very sturdy. I'm 260lbs and can stand on them (obviously I don't, but hopefully you get the picture.
The problem is, the floor attaches to the hull only about 3" under these "shelfs" lets call them. I'm worried when it's time to tab the new floors in I'll have two issues, #1 the new tabbing will only go up the hull a few inches, and #2 the difficulty tabbing in a such a small area under these.
I've attached some pictures that hopefully helps to understand what I'm saying.
I'm thinking about running the new floor to the hull as usual and attach with PB. Then adding an additional vertical piece from the new floor to the shelf again with PB. Basically closing-in the shelf area to floor. Then I will be able to tab several inches up the hull and down the shelf and onto the new flooring. The existing shelf stops about 12" from the transom and basically about 12" from the helm. I would extend the stern end of the shelf to the transom and taper the front edge to the area next to the helm as the floor also tapers to the bow at this point. Finally, I would cut a few circles in the shelf and fill the cavity with foam when I do the floors.
I really don't want to remove these shelfs and re-glass them later, plus I'm unsure if they also are designed to lend support to the hull.
Please see pics and my rough drawing, hopefully I explained everything correctly. Comments ??? TIA !
Thanks, yeah I've pretty much ruled out boxing in the "shelfs". I'm thinking of getting the floors in so I can get accurate measurements and just bite the bullet and remove the "shelf" and foam so I can tab the floor into the hull and then replace the shelf. It's only time and money right ???...Looks good , this build is very similar to what I just did with a 1993 Larson SEI 180 , transom slightly different but was made the same with 1/2'' sheet stapled over 1'' larger area of the transom, i replace it with 2 x 3/4" for the whole area. As for what you call the shelves , since they are only holding in place with some chopped strand on top and one layer on spray foam with a bit more chop gun, i was inclined to think not structural. The only explanation I had was in my boat they were only there to provide a level bottom surface for the storage on the side. I had enough room underneath to tab in new floor but from the shelf to stern I had to cut and remove this layer of chop gun and spray foam to get proper tabbing to hull. If you check my last post Larson SEI 180 Complete Rebuild | Boating Forum - iboats Boating Forums you can see how I covered it, not sure if it good or not but could not think of other solutions. As for the gas tank cover, to avoid screwing in the stringers, which are all covered with 6oz cloth and epoxy, I epoxied pieces of 1/2'' ply to stringers that I can screw into, if rot gets in them it will be isolated from structural members as long as they can hold those screws life is good. Boxing in that shelf may not be a great idea, it may change dynamics on how the hull flexes laterally, causing higher stress in an area not designed for it. Again just an opinion probably be fine but I would hate seeing the gel coat spidercrack at that exact location along the hull. Sorry I don't have many pictures posted can look for more if you need em.
Good luck
Much respect! I'm nowhere near as fast and have half the cylinders, but racing is great fun, and the sport is full of great people.Oh Boy, we would have to start a new thread on probably a different forum to go through all the cars I've built, LOL.
That it is, that it is.Much respect! I'm nowhere near as fast and have half the cylinders, but racing is great fun, and the sport is full of great people.
