Restoring a Jon boat
Basher 55
I purchased a used Sea Sprite 18 foot Jon Boat. I"m now stripping the old paint off. I plan to keep it bare aluminum. Some one used a wire wheel to ruff the surface for paint. Some parts of the aluminum are badly oxidized along with ruff surface. Some parts of the hull shine like a new nickel.My questions are, how can I get the oxidation off the safest way. I'm using Mothers Mag and aluminum polish it works well shining the not so bad spots. I'll need to sand the ruff areas down, what grit should I start and end with. I know the aluminum is only so thick, is sanding the best method. My fear is weakening the structure by sanding (keep in mind I'm handy, its not my first redo). If a loss ( by sanding) of say a 1000 of an inch or less really hurt the integrity of the vessel? I'm only concerned about the gunnels (sides) of the boat. The bottom will be painted. I am a river fishing guide, the launches are crude at best, with no docks, which means beaching when launching and recovering. What is the best method for protecting the keels? I tried to order keel protectors one company said they're not for application on a Jon boat, any recommendations? I-boat is a great forum! But when looking into this project through old forums my concern started. To many pros and cons with this subject. Thanks in advance for your help. Basher 55
5150abf
Re: Restoring a Jon boat
Start with a Scotch brite pad and work up from there, go with the grain of the aluminum in a straight line, if you can't find a grain then go front to back.(back to front)
If you want it really really shiny you will probably have to really work at it, I have polished aluminum and a biog area can be a real time eater.
If you do sand I would start with a finer grit, say 400 then go to 600 then a fine Scotch brite, like I said, depending on how shiney you want it it could be a long road for you.
And no, unless you go crazy with the paper you aren't going to weaken the aluminum.
ingalp01
Scotch-Brite and then an orbital buffer with a fine cutting compound, and then just polish... It will be lots of work, but it'll shine up nicely.
pootnic
There are products such as "steel flex","Gluv it",etc that are some type of epoxy paint.They are said to provide some toughness to the bottoms of boats.I've never used either but hear they can be alittle hard to work with.
