Restoring my 17' Century boat
Steve302
Hey Everyone.
I have been a boater for all of my 24 years and I have been coming on this forum for awhile now and have learned so much from all of you and for that I would like to thank you all. Now it is time to start my own project and I thought I would share my progress on here.
I bought my boat which is a 17' Century with a Merc 165 I/O (love this motor) in June 2010. I kind of lucked out as the previous owner had just bought a new sea-ray and needed to unload this boat quick because of lack of room for both boats in his driveway.
Anyways beside the motor being good he also did a good job maintaining the boat and installed a new floor, stringers, motor mounts and transom. I was a bit leery that he had done everything he said he had when I spoke on the phone with him but when I showed up to see the boat he gave me a folder full of parts receipts for these projects and I was able to check it all out and it really was solid as a rock.
The downside to this boat is that it's general appearance is worn out and old. The paint is really rough and looks like it has had at least one repaint and it was not done by a real over achiever if ya know what i mean. Also there are a few cracks and gouges in the fiberglass and all the hardware and wood trim are in pretty rough shape.
So off I went with my toy in tow. I took it home and made sure I had all of the safety gear on board and had it running good. I then enjoyed the summer with my new toy and the only problem it gave me was a broken throttle cable which was not big deal and i rebuilt the carb as it was running a bit rough.
I put the boat in the water at least 5 times a week all summer long which is probably more than it has seen in the last 5 years combined, and it never missed a beat so I am convinced it is worth putting money into it, to get it to look as good as it runs.
Anyways tomorrow I will start stripping the boat down so hopefully I will have some more pics for you but for now here is the before pics.
These are taken the day I brought it home.
Steve
86 century
Ensign
Re: Restoring my 17' Century boat
She has nice lines. I like those old centurys my '86 6meter was well built and road great.
Good Luck
ezmobee
Very cool hull with a great powerplant. Definitely worth the effort to fix up. Good luck with your project and welcome to the forum!
Steve302
Thanks I did not get much done on it today because i had a root canal yesterday and I was a bit more sore then I expected but I will post some pics of my progress later on today
Steve, the lines on that boat are purdy. I'm glad she runs good for you and has no structural issues. If appearance is all you need to worry about I'm envious! Good luck with your project and keep us posted! I've learned something from every thread on this site. Right AND wrong things to do.
Yacht Dr.
I want one of those !!
Personally If you were close to me.. Id consider Painting that for FREE ( plus materials of cource :) ).
Yacht Dr envy lol .
YD.
Steve302
lol well in that case michigan is not that far :)
As far as getting one it may be tough as it is the only one I have ever seen and have not been able to find out any info on it...
Steve302
Today was not a very productive day for me as my mouth was pretty sore but I did get out and take some pictures of my progress so far.
I should of taken more before pictures for you guys but I got started stripping everything off of the boat and kind of forgot.
Basically I have stripped all of the hardware off the boat which I will end up replacing with all new stuff as it is all in pretty rough shape. The seats and engine compartment are all out and I have not decided if I will keep the original setup which is two forward and rear facing seats up front and two seats on either side of the engine compartment in the back, or should I go with two bucket seats up front and extend the engine compartment so it is as wide as the boat and build a bench in front of it as this would give the boat a sunpad?
I plan on glassing in the dash where the original gauge cluster was and installing all new gauges and switch's as they are all in bad shape although they all work fine.
I have not decided whether or not I am going to put the vents back on the bow or whether I am going to glass over the holes and eliminate them altogether as they really do not serve much of a purpose and I think it would clean up the bow a bit. What do you think?
Anyways thats as far as I have gotten as of today and will begin sanding this week.
Steve
Yacht Dr.
I would probably leave the vents on the deck..but I can see it going either way.
YD.
captmello
Cool old boat!! What is the model name of your century? they used to have cool model names like Raven, Cheetah, Arabian, etc.
Steve302
To be honest I have no idea what model it is and was hoping someone could tell me. The guy I bought it off of seemed to think it was a Raven but I don't think so as I have found lots of pictures of them and it is not the same boat at all.
Started sanding it today. hopefully I can get far enough tomorrow to take some pics of my progress.
captmello
Keep it up. Whatever it is, it's going to great. I'll be watching for updates.
Steve302
I think i've nailed it. I found some pics online of a boat that is identical and he called it a 17' century raven. as for the year, the HIN is SR 7197. I'm guessing 71 is the year as i doubt its a 97 lol :p correct me if I am wrong...
1980Coronado
Yes...that's a 71 Raven....48th one built I believe....because production started with number 50 and this one is 97.....that would be number 48. You can get all new interior for that made from the original patterns from A&A Marine. Love the boat!
http://centuryboatclub.com/production/productionglass.htm
http://www.classicboating.com/centuryupholstery
As you can see...I'm partial to the Century Coronados....century made some great boats...to bad they are no longer in buisness. Your boat was manufactured in Manistee Michigan.
Steve302
Hey thanks for the links and your info. I really like the lines of the century boats and cannot wait to get some paint on the boat and see her shine.
As far as upholstery goes if I do change it up I would probably end up building new frames and going to see my uncle cause he owns an upholstery shop and did a really good job on my dads Carver.
1980Coronado
You're welcome.....just my 2cents.....the boat will be worth more if restored to original condition, but I understand the desire to customize as well..... Your boat, your choice.
Steve302
Still have not really decided what I am gonna do as far as keeping it original customizing it.
I like the idea of keeping it original but on the other side I like the idea of going resto-mod style too as it would be nice to have all new gauges and switches on the dash plus install a stereo and basically make it look like a 2011.
As for value, what would this boat be worth roughly when I am done? Not really planning on selling it but on the other hand it would kind of be fun to restore a boat every winter to give me something to do.
1980Coronado
If fully restored "better than new"....I would think you could get 8K-12k for it based on what I've seen in the past. I've seen some of the Resorters listed for 9K and up in that age group.....different boat though...more popular. There are several non-restored Ravens out there for sale right now in the 5K range, but they are several years younger and longer (18'-19') with a V8. It's tough to say exactly...don't have a feel for the market for Ravens. It doesn't appear that they sold as many of these as they did the Resorters, Coronados, Arabians etc.
Steve302
Just got back in from about a 4 hour sanding spree. everything is coated in blue dust including me :)
Starting to feel like I am getting somewhere even though I know I have a whole lot of work ahead of me yet. Hopefully i'll get down to west marine this weekend so I can pick up my primer and take a look at whats out there for everything else I will need.
Not sure if I am taking off to much off the old paint but there are a few different colors and a couple different primers so I figure it is best to get off as much as I can as this will probably make the body work a little easier.
I'll take some pics this afternoon.
1980Coronado
Have you considered taking the paint off and fixing the gel coat instead of paint? I've never done either, but am considering fixing some of the bumps and bruises on my boat. May pay someone to do it next winter. Just a thought.
