Restoring old spot light
Mark42
Re: Restoring old spot light
Just got a price on a 3 foot Teleflex Utility Cable.... $152.00. I thanked the parts guy for the time he put into tracking this down, but I have to decline. $152.00 for a stainless steel version of a lawn mower throttle cable is just out of line in my book.<br /><br />So I will keep looking.
Mark42
Thanks twidget,<br /><br />I check e-bay weekly, but so far I think I'm going to stick with the light I have, even it it takes a bit to get it working. One reason is that it fits the holes aready drilled in the deck (covered by a white plate on the starboard side) so I know it will cover them properly. Another is that it is the light offered by the MFG dealers at that time.<br /><br />I think I will just end up using the common hot rod manual choke cable for about $20 or the nicer cables I listed at the beginning of this tread for a bit more.
jeromeo
i have a similar light that was frozen solid when i got it.i hung it up in the garage and sprayed it with penetrating oil every time i went in there.i used every kind of oil i had (wd40,pb,3in1 etc)i eventually was able to get a small amount of movement-lots more oil and fiddling now it works exelennt. good luck
Eggkr8
Hey Mark,<br /><br />I was using a flex shaft on my cordless drill the other day and it hit me that that the flex shaft had something familar about it. It was pretty close to the cable used for the light controls. I am going to go to Home Depot tomorrow and look at this<br />http://www.homedepot.com/prel80/HDUS/EN_US/diy_main/pg_diy.jsp?BV_SessionID=@@@@0280957428.1109470877@@@@&BV_EngineID=ccdcadddmheejefcgelceffdfgidgmm.0&CNTTYPE=PROD_META&CNTKEY=mis c/searchResults.jsp&MID=9876&N=2984+3966&pos=n24<br />(yeah, cut and paste it)<br />I am thinking that this dremel cable will be similar and maybe work with it somehow<br /><br />I don't think this thread will ever die!
Tinkerer
Mark,<br /><br />First time I've looked at this thread.<br /><br />I've scanned the posts so far but I don't think this has been covered.<br /><br />I've had a fair bit of success freeing supposedly rusted solid parts. Most of them can be freed up given enough time and the right techniques.<br /><br />Try soaking you cable in diesel fuel for a few days or weeks if necessary. Or a rust dissolving fluid but they're a lot more expensive for the quantity you'll need. You might need to remove plastic or rubber parts in case they dissolve.<br /><br />Pull it out at least once a day and flex it and try to operate it. Once you get the tiniest bit of movement you're on the way home. <br /><br />It'll take a while but the movements will gradually get bigger and it'll speed up a lot more as they do.<br /><br />The trick is not to try to force it in one direction as that's likely to seize it against more gunge. If it gives a little bit one way turn or push it the other way. The gunge breaks down and lets the fluid penetrate more and the fluid helps flush the gunge out. Keep soaking it for long periods in between.<br /><br />Don't waste your time with WD40 until the thing starts to move. Despite its claims WD40 is more of a lubricant than a rust buster, at least on serious rust, but it's thin and gets into tight spaces once you've opened them up a bit.<br /><br />Spraying rust busters on is nowhere near as good as soaking as they don't penetrate.<br /><br />I'm guessing the frozen bit is inside the chrome housing. I don't know what long soaking will do to the pitted chrome but if it's going to be refinished anyway it won't matter.<br /><br />If all else fails you can always try heat, if you can get it somewhere it won't damage the chrome.
Eggkr8
LOL.. G-Dane... Sorry about that. All the time I have spent looking at this message and I totally missed your post up there.!<br /><br />Great idea by the way !! :eek:
Mark42
Will have to see if PBBlaster is available around me. Yeah, the cable is seized in the lamp housing. The rest of the cable is garbage because the outer cable housing flaked off. I will get back to woring on his in a month or two. Just as soon as I'm done with the basement (I'm ready for joint compound)<br /><br />Mark
Eggkr8
Hi Mark,<br /><br />PBlaster ROCKS! I have been using it for about 5 years now. It can even make nuts and bolts on a car exhaust loosen up. I always keep a can in my tool box<br /><br />Let me know if you aren't able to find it will help you out. Least I can do for the good advise I have gotten from you.<br /><br />If your cable housing is still solid, there is a good chance this will work. <br /><br />Cheers<br />Ethan
Eggkr8
Mark,<br /><br />I got some potentially good news about this subject. Drop me a line at ESandahl@aol.com if you are still trying to resolve this<br /><br />cheers<br />e<br /><br />PS, I told you this post will not die!
