restoring the Hull of a '94 Key West 1900 CC
Grits
I bought the referenced boat early last fall. It was in very good shape with 172 hours on the original motor. The previous owner was 82 years old.
The hull did have dock rash in a couple of places and there were some minor dings and scratches here and there. My intention was to use the boat and just have fun with it. That did not last long. Some of my hobbies are machine work, restoration of older machine tools, woodworking, gunsmithing, and many years ago sailing. What I am saying is I can never leave well enough alone and I have the equipment to do the work.
My first task was repairing the dock rash. The new gelcoat sprayed on so pretty and matched so well I ended up repairing every ding visible.
I sanded the hull with 320 dry with a random action orbital sander with a vacuum. After this I got to work on the console so my fishing partner could redo some of the wiring plus install hydraulic steering. I dry sanded through #400 and then wet sanded with a pneumatic DA sander through #1500.
the surface was smooth as glass (no pun intended). I then buffed with 3M High Gloss Gelcoat Compound. It looked great; however, upon close examination, the compound left some scratches.
The reason I am doing it this way is I find it easier to wet sand, with the equipment I have than buff and I also feel the finish is smoother.
What compound or polish (s) would you recommend after wet sanding through #1500. I guess i should not grip as good as it looks; however, I do not like the idea of taking out scratches and then putting more back in.
Thank you for all your help.
Grit
FYI-The boat is off white.
