Running a 96 merc 75 hp 2 cycle. Compression 110/105/105. Spark is strong. I am having troubles getting it started. It cranks and cranks but won't fire up (on the muffs). If the flywheel turns, does that mean the power head is OK? Or is there another way to test the power head??
Just found the restrictor / regulator has 2 wires (yellow) that are burnt at the connector. Down lower on the wire harness, there was one wire connector that was seperated (also yellow wire) or popped apart.
Does this mean the restrictor / regulator needs to be replaced? Or can the wires / connectors be replaced?? Any test possible? I have a volt meter but don't think that it reads ohms. Could a bad restrictor / regulator be a 'no start' reason? Any ideas or tell tales here?
The motor ran on lake for a few hours last week and may have run into some oil pump problems, starved for oil. Wondering if I replace the res/reg it might just lead to other replace items and other replace items.
Thanks.
Thanks.
