After doing a fair amount of reading on this forum and others, I decided that I was going to mold some hatch covers for the new deck I'm putting in my 1988 Donzi R-23. So naturally, I made a test piece to try out the process and see what would happen, before I get too deep.
Well let me tell you, it couldn't have turned out better. I'm super happy with the results of this first test piece. I made the mold using the following:
- 12"x24" white melamine covered particleboard (basically, a white shelf bought from HD)
- a length of plastic baseboard (also from HD)
- some wood putty
- clear lacquer spray
- nail gun
I cut the baseboard to length in order to make the 4 side walls. These walls were nailed onto the melamine slab and to each other. The inside corners were then filled with wood putty and a 1/4" round pipe was used to radius the corners. After the putty was dry, a light sanding cleaned up any rough edges. Once that was done, a few coats of clear lacquer spray were applied. When the clear lacquer was dry, the mold was ready.
I first applied 3 coats of carnuba paste wax. Afterwards, I sprayed on a couple coats of PVA mold release (using the $15 gravity feed spray gun I got from Harbor Freight). After the PVA was dry, I applied the first coat of unwaxed polyester resin. I added white pigment to this first coat, and brushed it on lightly so I wouldn't tear the PVA film. I then added a layer of light cloth (maybe 6oz? I don't know) and resin, then a layer of 1.5oz mat and resin, a piece of 1/2" plywood for a core, then a final layer of 1.5oz mat and waxed resin.
Once the piece hardened fully, I popped it out of the mold. I set up the fence on my table saw and cut the flanges to 5/8" length.
The surface finish turned out super smooth and glossy. I had some runs in the PVA (I applied it too thick and too fast) and those showed up in the final product (but they're barely noticeable). That's why this was a test piece
Some observations I made:
- need to spray the PVA in lighter coats in order to build it up
- waiting for the first layer of pigmented resin to become tacky before applying the first layer of cloth worked great to avoid any print through of the pattern
- 1/2" plywood core is WAY too thick for something of this size. The piece is super strong and stiff. A 1/4" core would have been just fine.
- The edges of the wood core need to be rounded in order for the mat to be able to lay flat and not lift at the edges.
- some wood putty
- nail gun
