dozerII
Thread starter- Joined
- Oct 25, 2009
- 6,527
1981 Mercruiser 140 Drive # 5961547, Replaced the water pump, shift shaft bushings with the updated ones, new shift cable and all bellows. Reassembled every thing and adjusted the shift cable. The lower unit seems to have an excess of front to back play in the prop shaft,about 1/4". When I shift to forward I get a good lock with ratchet in the other direction, in reverse it clicks in one direction and ratchets in the other, if I reach under the out drive and press on the shift fork to the port side it will lock solid. I tried taking the shift cable of the shift plate and pulling on it as hard as I can and it still won't lock into reverse without pressing on the shift fork. Any ideas.
Thanks in advance.
Thanks in advance.
