joeboater7
Thread starter- Joined
- Apr 23, 2012
- 27
I am brand new to this message board. I just recently purchased a '79 glastron hp154 bass boat with a mecury thunderbolt 500 50hp outboard (for $850). From browsing the message board you all seem very helpful and friendly, so thanks in advance for any advice you might give!
I noticed my reverse lock hooks were not engaging the trim/lock bar properly, even though they move as they should when I shift when the motor is held up. Closer inspection revealed the right hook was pinched shut a bit too much so that the hook wouldn't fit over the trim/lock bar.
I removed the spring, a few cotter pins, and slid the hook assembly off the motor.
Now here's where I am stuck. I have two questions:
1) How should I go about spreading the right hook open a bit more? It seems pretty solid and I just don't know how I might go about applying enough force to open it. Any suggestions?
2) I noticed the extension arm that comes out of the lower unit that controls the hook position is not attached in anyway into the lower unit. It pulls right out. After three or four minutes of blindly trying to find where it belongs in the lower unit, I did find what feels like a sleeve or seat that the extension rod slides into and seems to fit quite perfectly. When I shift it does move the extension rod. So I think I have it it the right location. It just seems odd to me that it is not fastened in any way to the lower unit. Is this normal?
Thanks a ton for your help!
