Reverse Polarity on a Mercury 2007 50 HP ELPT 4S
jerryski59
Getting my boat ready for the next day I mixed up my positive and negative cables wrong. I had to replace my trim fuse and the fuse to start the motor. Trim works fine but once I rotate the key to start I hear the beep than it blows the fuse (20 amp) . Trim still works My Motor is a 2007 Mercury 50 ELPT 4S HP . As I live not near a dealership to get this fixed I just need to know what part has to be replaced I will order it and replace it any help would be most helpful
wired247
Re: Reverse Polarity on a Mercury 2007 50 HP ELPT 4S
You blew your rectifier/regulator at least. Possibly the switchbox too.
jerryski59
Thanks for the advice much appreciated.
Timestep
Switchbox ??? The regulator will have blown, but lets hope the rest of the electronic systems are OK ?
You could unplug the wires going into the regulator and try it ?
Dave
jerryski59
Dave
Thanks Dave just ordered the manual will replace the regulator do you you know if its a regulator/ rectifier or just a regulator. once again thanks.
Timestep
Well, it turns the AC into a controlled DC voltage to change the battery. As I said, it will run without it, so try that first ?
Dave
jerryski59
Dave
Ok will do thanks again.
jerryski59
So I replaced the regulator still blows the fuse . I also disconnected the regulator still blows the fuse . ( Im lost )
jerryski59
removed the regulator rectifier still blows the fuse I don't get it
jerryski59
was the suppression diode $48 cdn 15min to replace
