Re: Reverse prob 60hp Johnson anyone on that can help!
Hello Reastburn,<br />The problem could be several things,bad gearcase oil,a plugged pump screen,sticking pump plunger,or a bad shift coil,or maybe not getting power to the coil. Check for power first, then check the resistance of the coils next. All of this can be checked without pulling the gear case.<br />Good luck
