Reverse
OBJ
Re: Reverse
I see 125 commercials (probably same block) but no 120's......gonna' be hard to ID the original year.....
MCM
Re: Reverse
Could be, curiosity got the better of me so I called them (ISHOP) this morning and gave them the RPH#, the rep. couldn't really give any more info other than call BRP. :rolleyes:
AJ__17@BELLSOUTH.NET
Re: Reverse
HMMM......<br /> Well the black box behind the "fly wheel", which is the big circular wheel with the teeth cprrect...? well then if that is it, then that black box is flat. And it also is in the shape of a trapezoid, when looking from above.<br />thnx, i hope this helps<br />art~ the novice fisherman
Re: Reverse
Well i took it to evinrude specialist and they said that the motor is a late 80's early 90's motor. He also stated that there are after market parts availible for low cost. so does the shop manual for that year covered in one booklet, or do i need to narrow it down some more? but he did say that the lower units for this commercial motor are assembled very similarly. so where do i go from here ? any suggestions?
