Rewire L.E.D. dock lights to panel
pgshields
Hey guys,
I recently just installed 2 L.E.D. cube lights on the front of my pontoon. I had to rewire it with thicker gauge wire and had to get a wire harness. The harness I got was a lot like this one here in the first link. It has a On/Off switch but nothing to run straight to the boat dash panel(The docking toggle switch that is OEM) I want to run the switch straight to the panel and not have to push the button. Is there anyway I can maybe strip the wires from the On/Off switch and go to the panel rocker? Any help would be great and very much appreciated. Thank you
bruceb58
Sure...you can cut out the on/off switch and then just connect the wires together. Not an issue at all.
pgshields
Stripped the wires off the button, and then directed them to the switch. Works great. Thank you
