rewirering outdrive position sencers
catpro1970
the wires on my outdrive position sensers are trashed what is the best way to run new wires without total teardown of outdrive? my gauge is always on the up position and yesterday i found out the wires were completely rotted from juntion box to the sensers. could i hook new wires to old ones and pull them threw or will this cause me to have a leak. congrats on don s keep up the good work!!
Re: rewirering outdrive position sencers
Pretty Tough Question to Answer without knowing What drive you have,........<br /><br />If it's a Merc.....Your "Plan" Won't Work......<br /><br />Even IF it Could be Done,...... Leakage would No Doubt be an Issue........<br />I Doubt that it can be done without pulling the Bellhousing.....
4 Reel
I too have an inop trim guage, 98 Alpha 1 gen 2,was wondering, has anyone had sucess leaving the bellows attached and removing the pivot bolts for a little extra clearance & changing the wiring that way?
rodbolt
why not just remove what the manual calls for and catch up on a bit of maint while your there?
4 Reel
Just did all bellows last season
tommays
haveing been in there as a rookie and knowing how tight it is the service manual is the only way to fly if you dont want to it twice :) <br /><br /><br />tommays
4 Reel
I was afraid of that, just trying to save some time
I/O WALDO
I have drilled a 1/4 in.hole in the upper,starboard side o the transom housing as close to the transom as possible (through the thin part of the housing)and routed the wires through that and either a hole drilled in transom above the waterline(with sealer n clamshell)or through an existing speedo hose or transducer wire hole. Ittsa option,only did it cause I could not git the wires out the original route.
I By-passed the Bullet connectors,......Cut the Wires,... And drive by My "Seat of the Pants" Gauge................... :)
thegodown
When I bought my boat the trim sensors had been replaced and the wires were passed through holes in the transom (above the waterline). I wasn't very happy about it and replaced and rerouted them correctly. I didn't like the idea of exposing the internals of the transom to water. Water is incredibly pervasive and can get into the smallest of places. Once there it does a lot of damage.
4 Reel
WW, I agree there are already too many holes in my transom.
