rothfm
Ensign
- Joined
- Sep 26, 2006
- 915
Been using the BRP, Iboats.net charts...and dont really have an answer to this. I've looked at the charts in the sticky too.
Rebuilding my '84 115hp. I believed spare lower unit I already had would be a match. Its a 1993 25" (same length of both). I test slipped it onto the Exhaust housing on the bench (minus Phead) and everything seems to fit aok. I then slipped just the Crank over the shaft splines--and they fit great too. Everything seems ok test fitting on the work bench.
However, in looking at all the year charts..These years dont look like an "exact" match, but some parts do--like the crankshaft and shift shaft.
Is it just gearing that is different? Am I going to be ok to use the LU '93? I do have a lead on an inexpensive 1988 LU from a 150 25", if someone can tell me if that might be better?
