bob johnson
Thread starter- Joined
- Feb 25, 2009
- 4,306
Motor in question 1999 JOHNSON Ocean Pro 150.....J150pxees. The motor was an oily mess so I am rebuilding the carbs....I took the power head off and installed it on a 1997 Fast Strike 175 hp mid and lower section because my boat has a 20" transom( more about why that might be important later).
so I found my carb bowls are warped beyond belief...but luckily I have a blown 1997 175hp ocean runner and the carb bowls are the came!!!! and... they are flat!!! so I am taking the high speed jets about and I notice the 175s are VERY shiny and look new... and the 150s are dull and dirty....but they have different #'s!!!! so I figure I cant interchange them!!!!!!!!!!!!
no problem.... I needed to order manifold gaskets that I forgot to order .. and I looked up high speed orifices for my 1999 150 power head.....and low and behold... they offer THREE different size orifices depending on the letters after the 150!!...if you have a J150PLEES, then you order #69D. if you have the J150PXEES you order the #59D(what mine had!!!!yeah).... and.... if you have the J150JPLEES you order the #70D orifices!!!!( I am sure that is a jet lower model.)
the 1997 175hp had nice #70D's......so I find it strange that in the end they do use different size orifices based on the shaft length and wether its a jet or not.....
if I put the #70D's in my 150 carbs...will it adversely effect the air -fuel ratio????
if I bought new it would cost me over $70.....
I haven't looked it up yet, but what are the IDs of each orifice???? and does the length of the lower unit really create that much of a different flow to need a carb change?
bob
bob
