Re: "Right in the middle of it!!" Carb question??!?
andy 6374:
The throttle shutters are completely closed, and synched to perfection to all open at the same time. I had done this earlier following the directions in the book and found them to be slightly off when I pulled the carbs last time. The culprit was some slight wear in the linkage that connects the two sides. Now they open evenly but it didn't help. I"ll check the choke trick but the problem seems to be more of a quick cough and pop rather than a longer sputter. The idle jets are the correct size, checked them all.
Dhadley:
Yeah, that was my thinking about the jets and especially the line about increasing horsepower. Should have seen that writing on the wall, but the guy did come highly recommended when I checked him out. After seeing some of the work he's done so far on the boat/motor I have serious reservations about his work. It was only a thought, possibly worth the $40.00 for new jets to try a different size. If you did have to re-jet it, any suggestions??
Iwonbat:
Next time I pull the carbs I'll check them out and get back to you if they're warped. Thanks!
Dennisanoka:
You know, I hadn't thought of that. They've all looked the same when I've pulled them before, but I might have been running it faster than an idle to even them out. I might run it up in the yard tomorrow and let it idle for a bit and check that out. I'm gonna bring a timing light out the next time I go to see if I can see a cylinder drop out.
Thanks for the suggestions, keep 'em coming if anything comes to mind. I'll update after looking into some of this.
Evan
