Ringing question
jim kinser
:confused: I'm rebuilding a 1996 200hp merc, bored two cyl. My question is ; will wisco or sierra std rings work on oem std pistons ???
Texasmark
Re: Ringing question
The www is a marvelous place. I'd www both mfgrs and ask the same question.
Mark
Faztbullet
Wiseco rings only fit Wiseco pistons, the Sierra will interchange if they have it in your serial number range. The 2.5 came with 2 different sizes rings, a 1.5mm and a 2mm thick so order by your serial number. The only ones supplied by Sierra is the 2 mm ring and Promarine is cheaper and has them (1.5 & 2MM) instock.
39-815515A12 --PISTON RING (STD.) (1-1/2 MM)XR6/MAGNUM III/175/200/TRACKER SN# 0G052594 & Below
39-822321A12 --RING KIT (STD.) (2MM)XR6/MAGNUM III/175/200/TRACKER SN# 0G052595 & Up
