Riser Bellows Adhesive
crawdadric
1993 Bayline Classic 19' 3.0L 4 cy 181 cu Alpha 1 Gen 2.<br />I was reading in the service manual about checking the exhaust shutter valve assembly and it mentioned to apply bellows adhesive on the bellows that covers the lower exhaust pipe/tube. I was wondering if you are supposed to put the bellows adhesive on the other bellows, that attaches between the Riser and the middle exhaust tube.<br />Thank you
Don S
Re: Riser Bellows Adhesive
No, they are not bellows, only tubes. The bellows gets pulled quite hard when the drive is up and the adhesive keeps it on. Make sure the surface is clean before you put the adhesive on it.
