Riser Gaskets Question 5.0 Closed Cooling
rick3452
Ser # 0M012817 2000 Bravo 3 do I have Full Flow or Restricted Flow gaskets on this engine.
Thanks, Just want to order the correct OEM gaskets.
Rick
HT32BSX115
Re: Riser Gaskets Question 5.0 Closed Cooling
Rick
Howdy,
If you have closed cooling, you have "Block-off" gaskets. Only coolant flows through your manifolds (and 3" or 4" extensions if you have them)
Raw water flows through your risers.
Cheers,
Rick
