Riser/Manifold leak?
LAC_STS
This is a new engine (in July) that came complete with these manifolds and risers.
I noticed a little tiny rust spot about a month ago and it has gotten worse and now as you can see the rust is all the way around where the riser meets the manifold, and you can see where water actually dripped down the manifold.
I re-torqued the riser bolts but I only got a little nudge out of them.
Should I replace the riser to manifold gasket?
Joshua Nichols
Re: Riser/Manifold leak?
did ya remove the primer from the manifold and riser where they join before they was installed? They got that stuff on there thick
LAC_STS
I didn't install them. The engine came complete. Manifolds, risers and all.
Maybe I should call the place I got it from? A new gasket if that's what's needed shouldn't be too bad though. Right?
Joshua Nichols
yeah going to need a gasket... Bet they left that paint on there
proshadetree
I would replace the gasket. No scene letting that rust pit up your mating surface
Ayuh,... Pull the risers, 'n LOOK....
If it's leaking to the Outside,...
It's probably leaking to the Inside as well...
LAC_STS
K. Ill pull them in the next day or two and post what I find.
Thanks everyone
