steve n carol
- Joined
- May 8, 2004
- 459
merc 225, 188hp 302 ford. Got the new BARR log style and risers, T-stat and hoses. Put the muffs on 'and farred that mamma uhp'. Prior to starting the engine, I checked water flow into the block and manifolds by opening up the petcocks. water came out of all of them except the petcock on each riser. When I installed the logs and pet cocks haha, I had to clear away the blue thread sealer. <br />Q), is there suppose to be water flowing through the riser petcocks? <br />after warm up and carb adj. While the engine was running, I opened these petcocks, nothing came out. logs were hot to the touch, risers a little warmer, the U pipes below the risers were much cooler, just warm. The gauge stayed at 175 for about 30 minutes. then went up to about 200. Well, no water in the oil....thats a good thing. The BARR risers are 'an improved style for better cooling'. I used the S.S. block off below the risers, just as with the originals. Any thoughts about the riser petcocks?
