risers getting hot when slow ed down
mark_fitzy
Not sure if this should be happening. Start the boat , motor warms up to correct temp. Take her for a run risers cool, temp Gauge good and then when I slow down, temp stays good , risers are good then slow down to a stop and have her idling, temp gauge still ok but risers start to get real hot and then after a few minutes its cools again.
Is this normal.?
Risers are 12 months old(brand new gaskets),Impellor is brand new, Plenty of water cirulation, Thermostat good working order
jerryjerry05
Re: risers getting hot when slow ed down
Since the risers are fairly new.The thermo has been tested.Then your not pumping enough water.That leaves the impeller,even though it's new.It only takes a couple of minutes to ruin one.J
