crazy charlie
Thread starter- Joined
- May 22, 2003
- 5,753
this has been an ongoing problem since last year.Twin 230 mercruiser ahpha i/os.RWC and used in salt.Fresh water flushed after EVERY use.At idle and idling up canals my port motor temp slowly climbs.If I tap up the throttle to 1100rpms ,the temp stops climbing and then comes back down .Underway it is fine,coming off plane a slight increase and then a decrease as normal.My starboard engine has begun doing the same thing this season.I just changed the mani and risers with no change.New impellers(entire kit),Tstats,Circulator pumps new in 05.Transom kits in 04.Bought new exhaust flappers but the old ones were fine.Backwashed p/s cooler.Tstat housing looks fine (but I may replace it anyway)I am to the point of confusion.I am wondering if a buildup of muck in the block may be causing this condition.The water is low and murky when I back into my slip and all kind of muck are churned up.I am almost to the point where I pour a gal of saltaway or muriatic acid in the block to see if there is anything in there that needs to be loosened up.ANY IDEAS ARE WELCOMED.No numbers on my temp gage,it approaches 1/2 way before I tap the idle up.Charlie
