Re: Rodbolt, I could use your advice on a C40TLRX timing problem
Grew2maxum,
I just did the same thing you did today, well almost. I actually was able to test mine at 4500rpms or WOT, whichever you prefer, in a test tank I setup at home. I used an old horse trough and placed boards on it with weight while I held the rpms long enough to check. This of course took 2 people cause things happen fast, water would still fly out and steering wheel would turn, etc.
Anyhow, I realized that (on the pro 50) once your throttle position hits a certain point, it is already at full advance, usually before WOT. So in a sense, it doesn't have to be fully WOT. If you observe the CDI pointer when moving the throttle, which rides on the large plastic foot, it reaches full timing before WOT.
I did attempt to do as you said, and adjust that full advance at idle (since the Seloc wasn't quite clear as to idle or 4500rpms) but it didn't feel right revving it up like that. I ended up blowing water out the old trough about 4 times before I got it all right.
I need to take it to the lake and test now, but it seems to run a hell of alot better when I shower down on it. It use to stumble and stammer around. Now it seems to get quick. FWIW, I've been messing with the timing and carbs on this thing for around 4 years on and off..I think I'm much closer now though. My full retard screw is like one thread of fully bottoming out along with my CDI pointer being to it's full extent (screwed on by 3 threads) as well. I can't wait to see what it does in the water now.
