This is really getting strange. Yamaha 1999 C40TLRX still has the high speed cutout or miss, like it is dropping a cylinder at high RPMs . but when I take the cowling and silencer off of the front of the carbs it runs fine WOT, no miss or cut out. Reinstall the silencer and it cuts out a lot at WOT.
I have been through the carbs 5 or 6 times in the last month cleaning and blowing out, looking for something causing the problems, even put in kits. Only thing I have found so far is a small piece of rubber tubing stuck in a needle seat that came from me pulling and reinstalling the carbs so many times, and that was apparent as that cylinder would not fire at all.
Fuel pump pressure is 5psi at WOT and there are no air bubbles coming through to carbs. All of the Ohm readings check out on the ignition coils and other coils also. Compression is good on all 3 cylinders 118-121 psi.
I have checked and #1 & #3 carbs have #115 main jets in them and I am almost positive #2 has #118 jet but will have to look closer next time I have it off. I was mainly looking to see if someone had swapped the jets to the wrong carbs, but when I saw the two #115 in the top and bottom I assumed the middle one had the correct one in it also.
I found all 3 of the Idle jet rubber plugs loose and in the bottom of the bowls last time I opened the carbs. Have you seen this happen before? I have read where someone else found this also after having the carb kits installed by a yamaha shop but no one ever gave a explanation for it or said how the plugs being out would affect the running. My thoughts are it would cause it to run rich at high rpms but am not sure.
Am I correct in the positioning of the jets?I have not seen anything in the manual about where they go, just that the specks call for 2 #115 and 1 #118 for the 40 hp.
Maybe the jets have been opened up by someone(I am the 3rd owner)but I do not think so. It had just a intermittent problem ever since I bought it almost a year ago but nothing as bad as now.
how do you find out what size the orifices are suppose to be?
I am sure I could find a real small set of drill bits that I could use to gauge the holes with and then measure with a set of calipers or mic.
Does this thing seem to be running rich if removing the restrictions (silencer)from the front of carbs makes it run better?and have you heard of this before?
I have put in 2 new sets if sparkplugs but no difference. Do you think a larger plug gap or hotter plugs would help? The 50 hp uses different plugs, but I do not like installing the wrong plugs in a motor.
Any and all thoughts will help
