Roller Pins
captainron19
Getting ready to replace my wobble rollers...... is it ok to use larger cotter pins to secure rollers onto the shaft or should I stick with the clips that came with the rollers?
MH Hawker
Re: Roller Pins
The clips are just simpler but yes you can use cotter pins if you want to drill each pin and use a flat washer and make sure nothing sticks up to cut into the boat bottom.
