mattb100
Thread starter- Joined
- Feb 12, 2013
- 21
I had manifolds leak this summer and replaced them, everything seems OK. I began to wonder what the cylinders might look like so I decided to tear down top end this winter and check things out. A comp check before dis-assembly showed 160 psi on 1,3,4,5 and 180 on 2,6 seems OK but I still wanted to visually inspect cylinder conditions and check heads. My plan is for an edelbrock intake,( I installed an Edelbrock 600 carb this year), a basic head rebuild/valve job, and i can get a set of stamped steel roller tipped rockers for free. Any pros or cons to installing these. I believe they are 1.6 ratio. Thanks to all. Matt.
