Rookie I/O
oops!
Re: Rookie I/O
awesome .......
great to hear that.....there is a thread at the top of this forum on how to summerize your boat......
these guys are gonna have to tell ya about idle setting...but i think it would be more mixture than anything......
yup...... ya danced over a land mine that time.......next season...youll be prepaired
oops
Re: Rookie I/O
I think shes fine,,,whew.
Ayuh,........ :)
As for your Carb,+ the Elevation change,.....
It's alittle More involved than just turning a screw.....
It'll Probably need a change in the internal Jetting.......
mrmushroomman
Re: Rookie I/O
I have a 4.3 lx merc and i have 4 hoses on the front of the motor. Two little hoses and two big hoses. I pulled all drain plugs upper and lower to let water out. I tightened plugs and filled all 4 hoses with marine anti freeze. Is this correct? Do you fill all 4 hoses with antifreeze?
Don S
Re: Rookie I/O
The only way to know for sure is to start it up and see if anything is cracked. Way to many variables in your discription to say yes or no.
mrmushroomman
Re: Rookie I/O
Nothing is cracked. I just want to make sure that it's ok to put antifreeze in all 4 hoses.
Re: Rookie I/O
Ayuh,......
Is it going to Hurt anything,..??... Nope....
Will it Help anything,..??.. Nope.....
