rookie prop question
mikehorizon
I have a 1989 four winns horizon 4.3 omc cobra sterndrive. I clipped a rock and now no go, boat goes at low rpms but nothing when more acceleration is there some sort of shear pin to be replaced
thanks
mike
Re: rookie prop question
Ayuh,... Prop questions belong in the Prop Forum....
But,.. The prop has a rubber hub,.. Your's is Junk,.. Put a new prop on it...
steelespike
Probably a spun hub you can put an indeleble mark across the hub and test it
check the mark.Prop can be rehubbed.
