Firewalker688
Thread starter- Joined
- Mar 26, 2011
- 30
Hello there all...
I am putting the finishing touches on my bass tracker and the guages are fuctional but look bad against a restored console. The PO had installed a plate over one of the guage holes to mount a cig lighter. I like having the outlet there and will drill the right size hole and install it a bit more clean. I have a Tach and a Volt meter. Both are working although my volt meter has such a spread in values as many do. It only displays extreme high or low and I don't know where I am in between.
I need a guage to basically fill the hole. I would love to have a fuel guage but I use portable tanks so that is out. A depth sounder would be nice if I didn't have my fish finder in place and needed depth readings but it's an aluminum boat and I am not sure if that will interfere with the sounder. I really like the tach and I use it a lot. Speed is done on gps.
The boat has a 50 Mercury classic. Around 81-84 model. I would also like to have a temp or water pressure reading at the dash. I looked into this a while back and it looked like most guages/senders aren't compatible with my motor. I could see how a head temp sender would work with most though. Can you think of any more that are?
So what would you put in that slot if it was your project?
One more question: The tach hole is 3 3/8 inches. I have found a very limited amount of 3" guages. Should I just buy one and be happy with selection or try to open the hole to 4"? I have space but I think it would be a trick to cut that hole very accurate.
Thanks a million for any replies. I hope each of you are doing well.
Scott
Scott
