I've got the floor cut out of my 1991 Searay BR200. Basically the floor was rotten under both bucket seats but in good shape thru out the rest of the boat.<br /><br />My stringers are in good shape except between the bucket seats where one of them is rotten on top. I scraped/cut out about a 1" wide x 12" long x 2" deep swath of rotted wood. <br /><br />My plan to fix the stringer as opposed to cutting it out and replacing it is to use CPES to kill the rot fungus, epoxy resin over that, then fill the 1" X 12" x 2" void with epoxy wood filler. Is this a sound plan?<br /><br />2nd question is on the floatation foam. The foam was wet under the seats but dry as you moved forward and aft. Should I replace the removed foam with 2lb density or 4lb density two part expanding foam? Anyone know what Sea Ray used back then?<br /><br />Thanks,<br /><br />Jeff
