rotary engines ?
VELOCIS
Has anyone ever heard og using rotary/wankel engines in marine applications?<br /><br />I would have thought there may be some benefit to the extended rev range considering the lack of multiple gears ?<br /><br />I have an older complete 70HP engine setup minus a blown powerhead, some cash for a small rotary engine and a good imagination ! :D
ivar
Re: rotary engines ?
Extended rev range yes , but probably a lack of torque compared to a conventional setup.
rodbolt
yes its been tried and actually worked quite well. rotor sealing problems plaged the early versions and oil problems as well as excessive fuel comsumption. a rotary is almost a 2 cycle. they generate tremendous exhaust heat. and by the time the tech advances were made in seal technology the projects were just not economically viable<br />I have seen the 2 rotor mazda used on airboats and inboard small boats but it was a frankenstien:) :) .<br /> good luck and give it a try.
ED21
Rotaries always suffered with lack of fuel economy.<br />I drove a Mazda RX-7 some back in the mid '80's & it would push you back in the seat like any V8.<br />The car was geared low, so maybe the high reving helped its performance. <br />Don't know anything about its torque without the gearbox attached.<br />It could spin tires easily into 3rd gear if you wanted.
JB
I drove an experimental prototype 35HP rotary Evinrude back in the mid-late 60s at Waukeegan.<br /><br />Lousy hole shot, but fast for a 35hp. VERY noisy.<br /><br />It was developed from OMC Snomobile rotarys.<br /><br />Never got beyond prototype. Don't know the reason.
VELOCIS
wow JB thats about as close as I'm gonna get, someone who has actually seen a prototype.<br />So I know it may be asking a little much but do you happen to know how many cubic centimetres that rotary was to get 35HP and was it a single rotary ?<br />Anything else you could tell me about it.<br /><br />Thanks to the rest of you for sharing your experiences of RX7's etc.<br /><br />RX7's are still always a popular power mobile over here in Australia..<br /><br />Cheers
Dhadley
"Back in the day" OMC put a rotary on a raceboat and outran the twin Merc powered boats. Since Merc runs the APBA the rotarys were invited to not return.
jim dozier
There are some jet boats that have Rotax powered jet drives in them. I may be wrong but I think that a couple of them were supercharged. I'm waiting for a E-tec direct injected 3 rotor outboard myself.
Chinewalker
There was a small Wankel powered outboard called the American Marc 10 made back in the 1960s or 70s. Saw one running at a meet a couple years ago. VERY loud, but seemed to run alright. Funky looking powerhead, too...<br />- Scott
phatmanmike
there is a wankel 10hp outboard for sale in local"bargain trader" paper here for 1675 obo...., i dont know anything about it though, its a 1971 and has never been on a boat, only "test tank" hours...supposedly
Chinewalker
That's what I get for trusting my memory with something I read a long time ago. The Marc 10 was indeed of Italian origin....<br />- Scott
RotaryRacer
Originally posted by jimd:<br /> There are some jet boats that have Rotax powered jet drives in them. I may be wrong but I think that a couple of them were supercharged. I'm waiting for a E-tec direct injected 3 rotor outboard myself.
the Bombardier Rotax engines are not rotary engines. They have pistons.
jim dozier
Sorry, I just assumed that a Rotax was a rotary. I see from some other links that they make piston engines as well, my bad.
RotaryRacer
VELOCIS,<br /><br />I think you have a great idea. Obviously the Mazda engines are the most widely available. You could probably create a single rotor engine by taking parts from a Mazda engine. The only part that you would need to fabricate or have made is an ecnetric shaft.<br /><br />I suspect you could get 50-70 hp out of it pretty reliably. However as others have mentioned there isn't a lot of torque coming out of any rotary engine.<br /><br />The will be some work to get a carb on the thing. You may be able to use fuel injection.<br /><br />Also the engine oil is crucial to keeping the temp down. You would need to find a way to have an oil resevoir and a way to pump it through the engine. You would have to pre-mix the gas with some oil also b/c a rotary requires oil in the combustion chambers also to keep the apex seals working good.<br /><br />Water cooling will be required with a Mazda derived engine. So some sort of water pump will be required.<br /><br />This sounds like a good project. Post pictures if you do it.
RotaryRacer
Originally posted by jimd:<br /> Sorry, I just assumed that a Rotax was a rotary. I see from some other links that they make piston engines as well, my bad.
No problem. Just thought I would clarify it for you. I once thought the same thing actually. But then I saw a Sea-Doo that said "Rotax" and "Twin Cam" on it. There are no camshafts in a rotary engine so I then realized it must be a pistion engine and sure enough it is.
jim dozier
Interesting link Rotaryracer. My thought was that one of the problems of rotaries when compared to 4-strokes was fuel mileage and air pollution. There are a lot of old Mazda RX7s happily running around at 9000 rpm so I don't think reliability is a huge problem. If you combined an advanced direct injection fuel system similar to the new OMC E-tec with a rotary you would significantly improve the fuel mileage and exhuast pollution of a rotary. Then you would have an engine of simple design, high power to weight ratio, and high reliability.
